5 members (Stovebolt48, Otto Skorzeny, Youngin' Tut 59, DadsFirstPickup, baldeagle), 65 guests, and 4 robots.
Topics128,180
Posts1,057,148
Members48,464
hi all -- hope everyone is great! found a set of four 1930's chevy spoke rims with new tires -- six lug -- can anyone tell me how long this bolt pattern lasted? -- I have a line on a 56 rolling chassis, but do not know whether I will be able to use the 56' set up with the rims/tires -- if not, can find a new front, no problem -- thanks, chris
ps. will only be using two of the rims/tires; if any of you are interested, let me know --
GM has used the 6 on 5 1/2" pattern through out the history of its motor cars and trucks. '29 chevys used this pattern I know. 1/2 ton trucks through the late 60s used this pattern. 4x4s used this until the present, I think. The lug size changed along the way. Current 1/2 ton Silverados uses this pattern. As did many other manufacturers.
I cannot tell by your post what your intensions are with the wire wheels. If it is to use on a 56 truck or car, the 1930 wheels will not handle the loads generated by these vehicles. Nor can I imagin that they would ever look period correct on any 1950s vehicle. But, as far as taste goes, to each his own.
It occured to me that you may be building an 1930 car or truck. In that case the 56 axles are much too wide.
I don't think that they would clear the brake drums, either.
GM (at least Chevy and Olds, not sure about Buick, Pontiac, and Cadillac) used the 6 lug wheels to '48 on Passenger, 2wd 1/2 tons to '70 (restarted w/6 lug in '99, all 1/2 tons, '88 on ligth 3/4 ton 2 and 4 wd) 4x4 1/2 tons '57 ('55 for GMC) to current. Also, pre-'47 3/4 tons used 6 lug as well. Most 6 lug Chevies (pre-'88) use 7/16" studs, '88 (GMT 400 chassis) to current use 14mm x 1.50 metric studs.
Bill Burmeister
When I was a kid and there were still 30's running around, it was common practice to mount disc wheels on the old vehicles when the spokes broke. Of course by then the 30's vehicles were 20 years old and they were out of style any way, but it sure made them look like something from Hicksville.
jeep uses them
Jim & Caroline
