| | | Forums66 Topics128,210 Posts1,057,465 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Hi guys I dont want spend 550 bucks to buys the bed side wall per side, instead, can I buy sheet metail and roll and the end and bend at an angle and make my own bed wall.
Is there any cheap tool to roll like that or am I completely insane.
Thanks for all the suggestions
Ganesh | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | $550 per side? Check other vendors. I had a local sheet metal place quote me to make bedsides and the roll presented a challenge for them. They wanted more to form the side panel than I paid for the whole thing complete with stake pockets and holes.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Instead of rolling the end why not weld a piece of steel tubing on? Might be a bit time consuming but you might not have an option... the tooling to make that roll isn't something you find every day. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | If you can reuse the roll from your sides. Cut the top of the bed about an inch below the bend and get sheet metal cut with an offset bent along the top. Weld it in with the offset to the outside from the inside of the bed. I am only welding about a 4" wide strip in where the bed side rails attached and rusted out. I will butt weld this but the offset may help reienforce the top. Rolling your own would be a real chore and probablly not something that I would try. Weld slow short beads. I like to tack each end of a long ewld then the center then the center of of the two halves then the center of the four quarters etc... Then you have to deal with the bottom.
Good luck
| | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | hmmm I would probably repair the side wall because it has been rusted out where the angle strip was orginally welded. I would cutt of all the bottom of the rusted area and add that piece alone
Thanks for your suggesstions
Ganesh | | | | | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | I am in the same situation w/my 54 3100. I think having the whole bed apart it will just be easier to breakdown and buy the parts new and start fresh. It will be tough parting with the cash, but it is the end result I am investing in.
Richard Gaglio
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | '54 - '87 step-side beds are all the same design I think. The different models have different holes for their fenders, but those could be filled in, and holes matching the '48 - '54 rear fenders could be drilled. I think the beds are wood up to '72... Worth a try, maybe? | | |
