| | | Forums66 Topics128,022 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | I am looking for a source for patch panels for my 46 Suburban-Carryall. I need the bottom of the cowl where the fenders attach and around the door openings. They would be the same as for a PU,yes? Does anyone make these? Thanks for your help, Richard
Richard J Patrick - 1946 Suburban
| | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Ray Stanley, Is the best around. I used his panels .like the ones you need 7 years ago with no fit or finish problems.
Currently he is rehabing a rear valance for me. He can work miracles.
Ray Stanley Metal Restoration PO Box 192 92 Pine St Wheelwright MA 01094 Work: 413 477 6467
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I"m not sure on 46 model but 47-54 front cowl sections you mentioned are the same as trucks. They can be purchased from several vendors. Be aware they may need to be "tweaked" to fit your vehicle. I'm sure a 46 owner will appear soon for confirmation.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
