3 members (JW51, tesa, Ponchogl),
49
0
Mod | | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45020 07/27/2003 8:01 PM | Joined: May 2003 Posts: 53 Member | | Member Joined: May 2003 Posts: 53 | Is there anybody out there that would know the lengths of the individual leafs on a 7 leaf 1/2 ton rear spring Thanks Biddaboy
1956 GMC TF 1/2 ton 1955 GMC 500 model (Gumby)
#45021 07/27/2003 9:06 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | All the stuff I have is for 3/4 tons. I am sure there is someone here who will come up with a correct answer
#45022 07/27/2003 9:24 PM | | Anonymous Unregistered | | Anonymous Unregistered | What year truck? The only 1/2ton ratings I see that use 7 leaves are for 55 second series. Part# 3712520 | | |
#45023 07/27/2003 11:42 PM | Joined: May 2003 Posts: 53 Member | | Member Joined: May 2003 Posts: 53 | Its a 1956 GMC 1/2 ton Thanks again
