6 members (Donf, FAST55, Danielbolt, cmayna, rfs56trk, Oswald), 67 guests, and 3 robots.
Topics128,154
Posts1,056,838
Members48,456
350 with a long shaft water pump. 1948 1/2 ton. My question is do I need to use the alum spacer that connects to the shaft of the water pump and the fan. I should have gone with a short shaft setup. Can't change it now because I purchased complete march pulley system.
What do you think? What radiator and source would you use?
Tom
48 Chevy 3100 Shortbox 5 window
"The Big Dog"
Yeah I'd use the spacer. But make sure it's on straight and doesn't wobble. That wobble can really kill the bearings in the water pump. You can get up to a 2.5" spacer, but that's getting pretty long. Depends on where your 350 is.
Most people move the 350 a few inches forward if they're using an automatic transmission just because you get some much needed clearance with the firewall. If you do that, you might not need a spacer to get the fan close to the radiator. I put my 350 in the stock location so that I could still use my 4 speed transmission. But that put the engine so far back that I needed a spacer to move the fan more forward.
I've abandoned my stock radiator for a modern truck crossflow radiator mounted just behind the front grill. It worked great until my NAPA water pump came apart and the fan tried to fly through the radiator. But they're doing the right thing and paying for the damage. This time, I'm going to put a fan guard behind my new radiator, even though a freak accident like that should never happen.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
