| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44938 06/18/2003 2:18 PM | Joined: Oct 2002 Posts: 10 Junior Member | | Junior Member Joined: Oct 2002 Posts: 10 | I have a set of these on my 57 3/4 ton and I have had many compliments on them. They are made by a company called AWC and mine also came new in the box. I gave $85 per wheel for the wheel, center cap, and lug nuts. The wheels do not rub on my 57, however you do need to be careful about the tire size. I am running 235x85x16 and I had to add the 1/4" spacer on the front to keep the tires from rubbing on the tie rod ends. | | |
#44939 06/18/2003 5:06 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 57 Mike, thankyou for your information. I have been trying to find rims with less backset than the standard Chevy rims, at 4 5/8 ". Now I have a line on who makes some. On the AD 1 Tons, the original backset is about 3". | | |
