Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (1 invisible), 146 guests, and 0 robots.
Topics128,290
Posts1,058,562
Members48,492
I am swapping a 235 for a 216 for the first time in my life and the learning curve is like a wall. I got a block and head '55 to 57 casting numbers matched OK but an incomplete motor. I bought a used rocker arm assembly from some old guy who said it'd work. The rockers have bushings in them and I think those were used on the earlier 216 engines. When I went to bolt down the assembly all the valves are held open- somethin' wrong big time. The pushrods measure correct, 11.25 inches, for 55 to 57. The towers appear to be the right height. The valves are all new and correct for the head. If I have 216 rocker arms would that be causing this problem?
With bushings? So like a 39-40 assembly for a 216. Not even close! eek
Here try:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2438337231&category=33617
Jim
Thanks very much for the guidance. I feel dumb but I had to ask somebody. That's what I get for digging around in a guy's backyard for parts. (And they were laying around dog poop too!) I got taken I do believe. Thanks for the ebay lead.
