4 members (C10 - C90 Bill, Gray_Ghost, Leo, Hotrod Lincoln), 105 guests, and 2 robots.
Topics128,100
Posts1,056,177
Members48,436
#447548 08/31/2008 3:45 PM
The shop manual says to "stake" the 216 Cam Bearings after installation.I'm not familiar with how is this accomplished?
Any help would be appreciated.
Drew
Staking simply involves drilling the bearing(s) for a small pin to prevent the bearing from rotating. Most everyone I know uses brads or small finish nails. Pick brass or mild steel brads, which ever is appropriate. For cam bearings, I'd be using brass. You'll have to carefully blend off the head of the brad with a fine file or emory paper after cutting the excess off with diagonal cutters.
Fred
I think that there is a hole in the cam bearing that is used for this purpose. I don't believe a pin is used. A punch is used to stake the bearing through the hole. I believe there is an illustration in the manual.
I hope that someone can comment on this further because this is a very important step.
1951 1 Ton Completed
Yup, truckernix is right, I just checked my manual and it's like he says. The manual shows a "Tool #7 (staking tool) for the job. Manual says to "mark the face of the cam bearing bores so that you have alignment for the oil holes, then press the bearings in and stake them in the hole provided". You can probably substitute a long 1/8" punch or center punch and just dimple the bearing into the hole provided.
My only experience with staking cam bearings is with F**d tractors. Sorry about the misinformation.
Fred
Yes, I found that illustration too. Thanks for your help guys.
Drew
