0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#44687 03/04/2004 11:38 PM
ape
Offline
Guy at the garage bled brakes. Brakes work fine now. duh. Truck sat for a couple months,then I put less than 5 miles on it. Brakes worked fine til last time when peddle went to the floor. Truck(a 40')has original ,rebuilt single master cylinder. Did air get into brakes while truck sat? Any ideas? Don't have a ton of confidence in those brakes.Lines etc are all new.Thanks.
Was the fluid level low?
54 3100 with 235
62 flatbed dump C60 with 261
You might check all your connections to make sure air is not entering the system. I have had that problem before.
Paint & Body Shop moderator
ape
Offline
Fluit was ok. Will check connections. Thanks.
D Online: Content
It is possible that the check valve got stuck in the open position. Sitting for a while will allow moisture to gum things up inside even a rebuilt master cylinder.
I learned a long time ago to keep an eye open for nice soft spots just in case....My last ride only had two rear wheel mechanical brakes.
1936 GMC T-14 1/2-Ton Pickup
ape
Offline
Lots of GOOD info here. Thanks ALL ! jim
Quality control on parts seems to be spotty at best. It pays to disassemble any "new" part to check out the machining,whether it's a brake part or an oil pump.
Don't believe that a dual system is absolute insurance against failure, because it isn't. When one half fails, the remaining working piston is usually moving in a slightly different position than normal. If there is any crud buildup there, you can lose it all.
1951 1 Ton Completed
