0 members (), 130 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
#446332 08/27/2008 10:38 PM
V
V Offline
rebuilt MC ran some new lines...can't build up pressure doing the pedal...did the one man bleeder...do I not have brakes adj. right or did I do something wrong in the MC? Thanks Virg
Start from the MC and work your way out. Crack the lines at the MC and see if you can get flow by pumping the brake. If not, you have your culprit.
If yes, then go to the left front and crack loose the fitting to the brake cylinder. Pump and check for flow. Eliminate each brake line as a culprit since one may be plugged or vapor locked. In any case, you won't get good pressure at the pedal until all of the air is eliminated from the system. Even a little air will cause a spongy pedal. Do you have residual valves? If so, one of them could be stuck open.
The only problem with a one man bleeder, is if you don't draw fluid fast enough, it can flow past a bubble in a brake line instead of drawing it out.
If all else fails, start from scratch.
1949 "Heinz 57"
