9 members (Rusted Nut, Otto Skorzeny, Gdads51, Bill Hanlon, TexasA&M48Truck, John L., 55shaker, Wally / Montana, Uncles51), 83 guests, and 6 robots.
Topics128,075
Posts1,056,003
Members48,433
#44612 09/13/2003 5:26 PM
READING THROUGH A PREVIOUS POST CONCERNING VACUUM ADVANCES I THINK I HAVE THE SAME PROBLEM. I HAVE ORDERED A NEW ONE AND IN LOOKING AT THE PICTURE OF IT DO YOU HAVE TO PULL THE DISTRIBUTOR TO REPLACE THE ADVANCE UNIT?
#44613 09/13/2003 8:14 PM
Yes, you do have to remove the distributor. The clamp that holds the distributor down and keeps it from turning is attached to the vacuum advance. The shop manual has a nice section on removing it. It tells you to turn the engine until the rotor is pointing perpendicularly out from the engine, then make a mark on the distributor housing where the rotor is. Then you can remove the distributor and know how to position the rotor when you put the distibutor back in.
MIne came out very easily. And my new vacuum advance works !!
My dad always told me, "Don't force it, get a bigger hammer".
