| | | Forums66 Topics128,078 Posts1,056,029 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 23 Apprentice | | Apprentice Joined: May 2007 Posts: 23 | i have a 64 stepside and have found a set of ralleys off of a 83 chevy 4x4 will they fit my truck. any info is greatly appreciated. | | | | | Joined: May 2007 Posts: 23 Apprentice | | Apprentice Joined: May 2007 Posts: 23 | someone please help me out i cant remember if its pre 85,86,87 or what 4x4 that will fit. ive been trying the search but nothing on this that i can find. | | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | Likely they will. But to be sure before you buy them, measure your bolt pattern, center to center between adjacent lugs and across between opposite lugs.
Have the seller do the same and you will know for sure before you buy them.
Also, don't forget to measure the center hole.
1949 "Heinz 57"
| | | | | Joined: May 2007 Posts: 23 Apprentice | | Apprentice Joined: May 2007 Posts: 23 | hey thanks for the response i was planning on doing that already and they are local in my area so that makes it easier. thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, they will fit just fine. '87 is the cutoff for fitment, although the Blazer and Suburban stayed with the same body to '91, so wheels from one of this up to '91 will also work. You may have to do some ligth grinding in the center hole, late Ralleys have 6 "tabs" in the center bore for aligning them on the later axle pilots. These will interfere with fitment on earlier trucks. Nothing to that, really. Just grind them down until they match the larger part of the center bore. If you have the rivets that hold the front drums to the hubs, those will need to be taken out as well, as they will interfere with the wheel bolting down solidly.
Bill Burmeister | | |
