1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | Do the cab mountings springs in my 1/2 ton just cushion the pulling of the cab away from the frame? I am refering to the springs behind the seat that appear on my rolling basket case to only cushion as the cab flys upward. Or are there some missing springs that cushion on the downward push but are gone? Either way it seems a strange design as it seems the fron of the cab is fully hard bolted to the frame with only a rubber pad between.----dave | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | seems they allow twist so as not to crack the wood cab parts independent of the frame twist | | |
