0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#444998 08/23/2008 8:38 PM
Hi all. While installing my timing cover, I broke off a tang on that metal strip that goes between the two bolt that secure the front cover from inside the oil pan. The metal strip's tangs are supposed to keep those bolts from backing out.
I've heard the tip/modification to make these accessible from the outside of the engine, but I'm not doing that right now.
I haven't seen a vendor that makes this part, and it isn't one I can fabricate (don't have the tools yet). I was thinking a lock washer and some loctite would solve this problem. What do you all think? Will this work? Is the part available?
Thanks!
I'm pretty sure that Loctite would do the job, just be sure there's no oil in the threads anywhere. But don't take my advice, I'm just guessing here.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Greg,
Loctite and/or lock washers should work fine.
However, you might want to reconsider tapping that fitting to allow removal from the outside. I did it last week and it took about 10 minutes. A friend was with me and he is also working on an engine in my garage. He was not going to tap his engine until he saw how easy this is to do.
Tim
