| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44472 02/27/2002 7:30 PM | Joined: Feb 2002 Posts: 2 Junior Member | | Junior Member Joined: Feb 2002 Posts: 2 | I have a 54 GMC 2ton with a 270. Is it a babbit motor or pressurized? Is it worth rebuilding and where would I get engine parts for this? | | |
#44473 02/27/2002 9:21 PM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | A GMC 270 oil system is pressurized. It has insert bearings. It is not a babbit beater. Engine parts can be expensive. Jim Carter Antique Truck Parts has a lot of engine parts. Many parts are still available through regular parts stores too. | | |
#44474 02/27/2002 11:40 PM | Joined: Oct 2001 Posts: 36 Member | | Member Joined: Oct 2001 Posts: 36 | NAH, it's not worth rebuilding---I'll give you $100 for it just to get it out of your way-----! Just kidding-these are very desireable engines. One was even used in an Indy car in the fifties--many, many of them were used in the sprint cars of the 50's and 60's. Check out Hot Rod magazines on Ebay for a cover photo of one modified to the max. with a Wayne head.--I think it's Dec. 1954 issue. As AFU said, check ALL the local parts stores/machine shops for parts prices before going to the catalog suppliers--they're usually much higher. | | |
#44475 02/28/2002 4:44 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Rebuilding parts and info. for GMC sixes available from Egge . I just emailed them and they "snail mailed" me a qoute. Jimmy sixes are full pressure oilers '39-'62!
*** GMC ***
