1 members (keithfielder), 129 guests, and 1 robot.
Topics128,162
Posts1,056,938
Members48,458
#44380 10/08/2003 12:25 PM
I
Junior Member
Junior Member
I Offline
Is it possible? I am getting a '54 235 but it is missing the waterpump and fan.
thanks
Those water pumps can't be swiched around. I've got a 216 and the pump has a plate (with two holes) that obscures the pump rotor. On a 235, the rotor is exposed. I know this only by comparison of my own engines.
BIG LIFTER
Tuna is the chicken of the sea
Iguana is the chicken of the tree
Chicken is the chicken of the three
knuckle head
knuckle head
1953 Powerglide and all 1954 235's were high pressure lube engines using the same water pump as the 216.The 55 and later 235 and 261 engines utilize the different pump.
Quote
Not all. Not the one in my garage, anyway. It's similar, I'll grant you. And it's a November 1953 block casting.
In any case, just buy a waterpump. You probably want a new/rebuilt one anyway, it's a false economoy to use a 50 year old pump...
Cheers!
George
