3 members (Dennys28, 87GN, 1 invisible), 113 guests, and 2 robots.
Topics128,059
Posts1,055,818
#44370 07/28/2004 6:33 PM
Hey Pork is back...This site kicks a$$.
Anyway, I bought new rear mounts and my '58 manual says the should be torques to 50lbs or so. As I start wrenching they seem to start expanding/flatten as if their going to blow out. Is 50lbs really the torque. I'm using the original 3 1/4" bolts. Is their a certain distance that the bolt end should stick out of the bell housing. Also the front mounts I just tightened securely.
pork-
59 1/2 ton 235 fleetside
"you can drink a girl pretty, but you can't drink a girl skinny"
1959 Chevy Fleetside 3100 Series BBW
#44371 07/28/2004 7:01 PM
H Online: Content
Since you're compressing a rubber mount, there will be considerable expansion before it gets tight enough. Use a little blue LocTite on the bolt thread, and sock it down. It's almost impossible to over-tighten those big bolts, unless you manage to strip the thread in the bellhousing. 50 ft/lb definitely won't hurt anything, threads or mounts.
#44372 07/28/2004 10:28 PM
Riding in the Passing Lane
There should be a sleeve around the bolt that
stops it at the correct distance. often they
are missing. they come with a lock plate at
the bolt head but I usualy use alock washer
instead.
1972 Chevy c10 Cheyenne Super
