| | | Forums66 Topics128,088 Posts1,056,381 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Have decided to put the 261 together for "Sludge" my '55 210 but now need .020 main and rod bearings and gasket kit to get the job done. Anyone know of a source? Looked on Patrick's and they have bearings for 235 but see only gasket set for 261. All help appreciated. | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Did you call Patrick's and talk to them? I bought 0.010 main and rod bearings for my 261 from them two years ago. Are not 261 and late 235 rod and main bearings the same? You could also try Chevy's of the forties or Jim Carter's Antique Trucks, or Egge. Are your main bearings the the tang or pin type? I have seen replacement engines for the 1954 261 that use the tang type, but the original 1954 261s used the pin type.
Hoyt
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Have not talked to Patrick's yet. Planning to call them tomorrow. Motor is a '59. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | 235's and 261's use the same main and rod bearings. Order them for the same year 235 and you will be fine.
Rods and pistons are not the same, though.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Patrick's catalog is a lot more thorough than the website. Ask for one if you call.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | 56pu,
I don't know about Omaha, but here in San Bernardino, there are several places that have or can get parts for the 235/261. I would make some local calls before I ordered engine parts from across the country. | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | 1956-62 235 & 261 engines:
Rod bearings: Federal-Mogul part # 6-1950CP(set) Individual rod bearing part # 1950CP TRW part # CB146P Undersizes available: 1-2-10-20-30-40-50-CA60
Main bearings: Federal-Mogul part # 960M TRW part # MS1721P Undersizes available: 1-10-20-30-40-50-60
The above numbers are from the Federal-Mogul master bearing catalog. Most automotive warehouses that have been around awhile will have access to those parts, but don't count on the amateur do-it-yourself stores like Auto Zone, etc. to be able to order them. NAPA should be a good source, even if they have to cross-reference to their own part numbers. Jerry
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Thanks to all who replied. Ended up having the shop order as they get a 20% discount--from Patrick's. They had everything I need--they even have a reasonably priced full rebuild kit--that I won't be needing. | | |
