| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | I am putting a signal switch on my stock 47. Does anyone know the simplest way to convert the stock parking lights to accept two filament bulbs?? I understand NAPA might have a conversion kit. Does anyone know the part # for them. I appreciate the help and advice. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I changed out the socket from a single to 2 contact style - you can buy the pigtails at most auto supply stores. My truck is 12v. Not sure about 6v stuff. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The socket would be the same 6v or 12v. The only difference would be the bulb used.
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | You will need a 2-filament bulb, which will require using a bulb socket with a different bayonet pin location as well as two insulated connectors instead of one. With a little work with a die grinder and some epoxy or solder, I can convert the light assembly to accept a different bulb socket. Not sure if anyone sells a kit to do it, though. Jerry
Edit: Just noticed you're a short distance from my farm, about 150 miles or so. Take a weekend road trip, and we can do the conversion in a day's time. I'm just off US highway 64, east of I-65 about 5 miles. Jerry
| | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | I appreciate all the info..I found a kit to convert the lights at Classic Parts. | | |
