4 members (68ironhead, Wayne67vert, GRNHydra, Oswald), 131 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#441693 08/14/2008 6:43 PM
Apprentice
Apprentice
I am putting a signal switch on my stock 47. Does anyone know the simplest way to convert the stock parking lights to accept two filament bulbs?? I understand NAPA might have a conversion kit. Does anyone know the part # for them. I appreciate the help and advice.
I changed out the socket from a single to 2 contact style - you can buy the pigtails at most auto supply stores. My truck is 12v. Not sure about 6v stuff.
1940 Chevy KC 1/2-Ton
Ex Hall Monitor
Ex Hall Monitor
The socket would be the same 6v or 12v. The only difference would be the bulb used.
You will need a 2-filament bulb, which will require using a bulb socket with a different bayonet pin location as well as two insulated connectors instead of one. With a little work with a die grinder and some epoxy or solder, I can convert the light assembly to accept a different bulb socket. Not sure if anyone sells a kit to do it, though.
Edit: Just noticed you're a short distance from my farm, about 150 miles or so. Take a weekend road trip, and we can do the conversion in a day's time. I'm just off US highway 64, east of I-65 about 5 miles.
Apprentice
Apprentice
I appreciate all the info..I found a kit to convert the lights at Classic Parts.
