1 members (JW51),
137
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Now that I have my truck on the road I can have fun with it and DRIVE!...BUT, I have some issues that I'm working out. What would be wrong with putting a pressurized radiator cap on my original 216? I have a BRAND NEW 3 row core on my radiator and a 160 degree thermostat. I have a non pressure radiator cap and it always boils over when I shut off the motor. Other than that, it runs real nice. :confused: | | |
#4390 05/26/2004 10:28 PM | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | John, unless you have someother problem, I think a pressure cap would be needed. For every pound pressure you put on your system, you raise the boiling point by two and a half degrees and especially if you are in a high elevation, the water will boil at a lower temp also. If you are running a fan clutch, that could be a problem or if your fan is too far from the radiator or if the fan shroud has been removed could cause over-heating. Truck Tinker | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I'd try a 7 pound cap first ... you don't want to put too much pressure on an older system; it could cause bigger problems.
My truck was boiling over when I first got it ... I found out it had NO thermostat in it! I put a 180 thermostat in (I have a 350 sbc) and all was well.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#4392 05/28/2004 12:38 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Thanks for the info. My motor is in it's original configeration, no shroud, no fan clutch. I don't know, maybe it wasn't boiling over. At the very top of my radiator there's an overflow tube that goes from the middle of the top all the way down the side. It's not connected to the radiator cap opening. The coolant is coming out of the bottom of that tube. So even if I use a pressurized cap the same thing would happen. Maybe I have too much coolant that is being expelled? :confused: | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There is supposed to be some air space in the top tank of the stock radiator, unlike in modern ones. The overflow should puke a little coolant until it stabilizes. If it keeps doing it and the level drops below the top of the fins then you have a problem, otherwise just let it puke and leave it alone.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Or you could install an overflow tank, like I did: See Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Yea, I was thinking of adding an overflow tank but it's gotta look old. Call me anal, but I don't want anything modern looking on my truck. I'm gonna check around and see what I can come up with. john. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Cool idea, John.
I sure don't like the LOOKS of mine at all ... it'd be much cooler to find some old antique jug of some kind to use! Only, it needs to be something that's easy enough to add the hoses to.
Any bright ideas? This puts a whole new light on garage sales and flea markets!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | hmm... old jugs with hoses connecting to it ...
just make sure someone doesn't mistake it for a home brewery and try drinking it
oh wait, these are "post"-prohibition trucks, right?
lol lol
Husker | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Several of the vendors have a reproduction overflow tank. There are expensive though. Try Chevs of the 40s or Filling Station.
Winona 1949 3100 5 Window Deluxe Cab
| | | | | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | not meaning to hi jack the thread but horvath what about useing an old Glass Washer jar from a car of the 50's? I had a 1955 olds 88 tha thad a glass window washer jar (I may still have the jar/no top) but the bracket and hoses you would have to fabricate. I think that would look more vintage.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Most folks just add the plastic tank like you did but you needn't cut the original overflow tube , as long as the puke tank is higher than the top tank it'll siphon back in just fine .
No more than a 4 # cap unless you want to test your radiator and heater core for leaks .
The repop puke tanks are very nice but overly costly IMO .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
| | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | If the overflow tank needs to be higher then the top tank of the radiator then I guess it won't work on my truck. 'Cause the top of my radiator is allmost a foot higher the the fenders. I would've liked to mount an overflow tank on the inner fender. If I mount way over on the firewall it would look kinda corny. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Brian -- cool idea! Steppinwood -- I agree; it looks horrible, but the firewall works for me ... I'm more into function than show. But, again, something vintage - especially in such an obvious-looking spot - would be awesome! Even an old mason jar would look pretty cool ... question is how to get the hoses happening.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Sep 2003 Posts: 23 Member | | Member Joined: Sep 2003 Posts: 23 | 216’s are not my area of expertise. Please, educate me as to why the coolant bottle has to be higher than top of the radiator. I installed a coolant jug on my 56 a few years ago. It is a 235 with a 7 lb cap. The jug is lower than the top of the radiator and it works fine. When the engine cools down, it draws the coolant back into the system. What is different with a 216 cooling system? It seems to me with a 3 to 7 lb cap, it would work the same. Or do the 216 Chevy trucks have a similar set up to the old GMCs?
I installed my coolant jug because of my employer. They freak out when they see coolant in the parking lot. They have emergency response teams to clean up leaks. My understanding is that Cal EPA can fine them for spillage, but that another topic | | | | | Joined: Jul 2001 Posts: 14 Junior Member | | Junior Member Joined: Jul 2001 Posts: 14 | My 216 has a pressure cap and never runs hot or "pukes" when I shut it off.
'52 Chevy 5-window 1/2 ton PU '52 Chevy short school bus
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | The puke tank will work at any level, as long as the line going into it is below the level of the coolant in the tank. I've used a 1-quart paint thinner can with a piece of copper tubing soldered into the screw-on cap, and a small vent hole drilled into the top of the can. Run a rubber hose from the end of the puke tube to the tubing in the can. Fill the can about 1/3 with coolant, and make the copper tube go to within about 1/2" of the bottom of the can. When the radiator pukes a little fluid, the can catches it, and it siphons back into the radiator when the engine cools down and creates a vacuum in the cooling system. I mounted the can to the core support with a piece of sheet metal soldered to the can, and a couple of sheet metal screws into the core support. Paint everything flat black, and it looks original. Be sure the cap you install has a spring-loaded vent valve that will allow vacuum to refill the radiator. A 7# cap should be plenty of pressure without damaging the radiator or heater. Jerry
| | | | | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | John, I got the "generic" coolant overflow tank from the Filling Station a couple of years back. Here's a pic (it's the stainless steel cylinder on the firewall) Coolant recovery tank It works good but if I were doing it again, I would look for one of the original optional "Radiator Overflow Condensers" that looked a bit like a coffee can and mounted in the same location on the Advance Design series trucks. | | |
