3 members (Nick in Manitou, Bill Hanlon, Stovebolt48), 76 guests, and 2 robots.
Topics128,035
Posts1,055,559
#44016 01/21/2004 7:30 PM
i threw a main in my old 235 and found a 235 out of a 62 at a reasonable price. i had to change the water pump but the only other problem i have run into is getting the accelerator rod to adapt to the linkage on the 62. i tried using the old linkage and that didn't help. anybody had similar problems. do i need to just get mad at the old rod and start cutting and bending?? millere@whitesboroisd.org
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#44017 01/21/2004 9:06 PM
Can you take the old linkage off your old carb and put it on the new one? Surely they are similar carbs but only the linkage is different? Then you can just use your old rods.
54 3100 with 235
62 flatbed dump C60 with 261
#44018 01/21/2004 9:21 PM
Quote
i will take another look at that this weekend. the actual problem as i see it is not actually at the carb but attaching the acc.pedal rod that goes through the floor board to the bracket on the block to which the rod to the carb is attached. (did that make any sense) anyway, the way it is now causes my pedal to stand almost straght up and down and i can't get the pedal to fit on the rod.
#44019 01/21/2004 9:45 PM
Oh that is right, it is the attachment to the block that is different. Others might have ideas on that one. I guess they changed the block.
54 3100 with 235
#44020 01/21/2004 11:35 PM
I beleive i used the atachment from the 216 on the block but cant rember for sure.I had to cut, weld and do a little bending on the accelerator pedal lincage to shorten and get it to fit on my 216 to 235 swap.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#44021 01/21/2004 11:45 PM
Junior Member
Junior Member
I had the same problem. I used the bracket from the 216. When I get home I will email you a picture of my setup.
1953 Chevy 1/2 ton
http://www.splakow.com
#44022 01/22/2004 2:13 AM
I have a 54 GMC, which had a Chevy 261 in it when I bought it and it appears that they cut, shortened,welded the gas pedal rod at the clevis pin end to make it work with 261 engine.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#44023 01/22/2004 2:27 PM
thanks for the help guys. i have been kind of lax working on my truck which is a nice way of saying that i can't afford much right now but sure enjoy tinkering around with it when i get the chance. i am sure i will run into a few more problems and it looks like i have found the place to get all the help! thanks again
#44024 01/22/2004 5:44 PM
4ontheFloor has a good picture of what he did to solve that problem.
For my '61 261, I took a piece of 1/4" rod and made 8 (yes 8!) bends in it. It only took me two attempts. It seems to have worked but I'm getting an exhaust pipe made today.
#44025 01/22/2004 9:29 PM
And here it is:
[img]http://photo.starblvd.net/guitarzan/1-1-3.jpg[/img]
You can just see the tip of the accelerator linkage rod. I shortened it with a grinder and bent the end over. You may also need to adjust the curvature of the accelerator rod, which I did with a hammer against an anvil vise. I had to take some of it out.
The rod between the bell crank and the carb is a piece of custom bent threaded rod with ball joint ends that I picked up at the hardware store for about $2 each. The linkage is very smooth.
Paint & Body Shop moderator
#44026 01/22/2004 10:21 PM
thanks for the great picture - it will be a big help. thanks to all for your imput!
#44027 01/23/2004 2:09 AM
Ok, im confussed.Isee that joshia shortened the rod from the carb to the bellcrank.On my 51 216 to 54 235 swap, i had to shorten the rod that goes from the bellcrank to the accelerator pedal by i belive something like 3 inches.The rod from the bellcrank to carb was fine but my pedal was leaning almost twards me in the seat.Am i makeing any sense here?
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#44028 01/23/2004 3:38 AM
djed50,
My 1960 261's block has the pivot mounted on the nearer to the gas pedal than it is mounted on a 235 1/2 block (my 261 came out of a large school bus). I shortened my pedal rod as described above by Slow..Rider.
My 1954 235 allows for mounting the pivot in either location (two threaded holes are provided; one for the pivot and the other gets a plug).
Tim
#44029 01/23/2004 4:37 AM
I had to remove the linkage to get my new exhaust pipe in. I don't have another pivot point on my '61 261 xxxxx925 block so I'll have try something else. I've seen 3 different pivot levers in the 216/235/261 series. Maybe a different one will help.
#44030 01/23/2004 6:01 AM
There were at least two bell cranks used on 216-235-261 linkage. My 216 bell crank was a cast iron (steel) piece and the 261 bell crank I'm using was a metal stamped bracket type. Each is different from the other. The only way I finally got mine to work right was to get all of the different pieces together (went to the wrecking yard and started taking all the different ones I could find). Finally I started working with them and came up with a system that would work. Switching around parts and bending rods are part of what you have to do to make it work. I have a 56 - 261 and on that block, I have a choice of two different bell crank location mounts. You just have to work with it until you get it. Hopefully this a message of encouragement!
#44031 01/23/2004 2:28 PM
i was not "educated enuf" to look for a different placement - that might solve some problems also. also painted my motor chevy orange before i realized it was suppose to be chevy blue/gray. you all don't holler at me too much over that one will you?
#44032 01/24/2004 3:20 AM
Mine is orange! Orange is OK.
#44033 01/26/2004 4:02 PM
by the way. where are you all getting those 261 motors that i keep hearing about? are they a easy swap out for the 235?
#44034 01/26/2004 8:30 PM
I had to shorten my pedal rod too, sorry if I didn't make that clear.
I got my 261 from someone who had a '62 Suburban and wanted to put a 250 in it. I traded him straight across for a 250 I had gotten for free. 261's were an optional motor in 2-ton trucks and busses. They are basically a bored 235 but the cylinders are siamesed, they have extra water passages to the head, and heavier rods. The '58 and up have full flow oil filtration.
#44035 01/26/2004 8:55 PM
thanks for that info 4inthefloor. i doubt that i will make that switch but you never know what might turn up. i have a parked 74 chevy pu that has a 350, power steering, auto trans etc that i am keeping around just in case the old 235 gives out on me again. really like what i got if i can just figure out a simple, inexpensive way to get a different rear end ratio for the highway. heavy on the simple and inexpensive.
