| | | Forums66 Topics128,122 Posts1,056,331 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | 59 1/2 Ton with 235.
Bought one of the Langdon HEI Distributors and separate HEI coils, both through Jim Carter. Does the ignition resistor bottom wire (dark green) still get used and hook to the battery side of the coil along with the hot (pink) wire of the new distributor.
The new distributor has the pink wire which is supposed to go to the BATT side of the coil and a brown wire which goes to the other post. I was wondering if the resistor wire still comes into play. Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to check the instructions. The factory HEI does not use a resister but most conversion kits do. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | I will call carter and see if they have instructions. Only thing I got was a small picture of the two wires going on the coil and a note that calls for 10 gauge wire to the Battery side. I assume this will come from the ignition switch to power it up and can eliminate the resistor but not certain. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Why would any instructions call for a #10AWG wire in an ignition system? I have an aftermarket distributor with external coil and resistor (Mallory). The manuf. supplied wiring and makeup wires are not even close to a #10AWG.
| | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | that can of worms has been open here before, most claim that the hei draws enough amps to require a 10 ga wire. when i did mine i didnt really know for sure but 10 ga wire is fairly easy to come by so why not. philip | | | | | Joined: Feb 2004 Posts: 29,809 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,809 | The GM HEI coil has such a low primary winding resistance that it's necessary to use a big wire to allow it to come up to full charge on the magnetism quickly. Once the magnetic core is saturated properly, they use a combination of the inductive reactance of the coil windings and a built-in current limiter to prevent overloading of the transistor amplifier in the ignition module. Jerry
| | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | yea yea thats what i meant to say. philip | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Sounds like I do not want the OEM resistor in the mix with the HEI? Is running the 10 gauge wire from the start terminal of the on off switch (foot stomp 3 pole switch) to the BATT side of the coil and leaving out the resistor going to hurt anything. My limited understanding of the resistor is to limit during starting? | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Rasman57 Before you use or lose the resistor contact the vendor or manufacturer. You may do harm to your expensive system unless you know for sure. Hotrod Lincoln I see the logic but with the Mallory aftermarket system the supplied wires from the manufacturer are not #10AWG. They are supplied with the unit and the user supply wires are connected to them with the supplied connector. Unless one wishes to tear into the distributor for a rewire then I see no reason to run #10 wire to the connector. Then again, my electric fan runs at about 15 amps and the supplied wires are not even close to the correct size. I'm confused.
| | | | | Joined: Feb 2004 Posts: 29,809 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,809 | It's possible the Mallory system is a capacitive discharge setup instead of the standard HEI. That type works completely differently, actually firing the plug 4 or 5 times in the same time frame as the one hot spark from the HEI. It's easy to spot the CD secondary voltage pattern on an oscilloscope- - - -there's actually 4 or 5 spark lines in about 5 milliseconds. I prefer HEI systems to CD, but it's necessary to have a good battery to supply the starter and the current demand of the HEI at the same time. MSD systems are a good example of the CD setup. I'm not familiar with how the Mallory works, as I stopped using Mallory distributors back in the early 1980's. Jerry
| | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Carter's HEI mini reqires the use of the special period correct looking external coil. However that coil says "EXTERNAL RESISTOR REQUIRED" I sent a note to Tom Langdon as he makes these up for Carter asking him if the external resistor means the OEM ballast resistor or if it is something different. | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | FYI. Tom Langdon sent me info on the Mini HEI and it says to NOT use the OEM ballast resistor. So I am going to leave the wires and resistor on the cowl for originality appearance and in case it is ever needed. I will run the 10 gauge wire direct to the coil as he instructed. | | |
