3 members (Southerntruck, 2-Ton, 1 invisible), 78 guests, and 3 robots.
Topics128,142
Posts1,056,491
Members48,442
Apprentice
Apprentice
Need a little help, I am trying to find a six volt Signal Stat turn signal and flasher. I found the switch at NAPA but they are all 12V and no 6V flasher is listed. Anybody know where I can get a 6v version of the switch or at least the 6V bulb to modify the 12v one at NAPA? Thanks from hot Memphis
Riding in the Passing Lane
A 12 volt switch will work on 6 volts if you change the pilot bulb or use indicators on the dash. The 6 volt bulbs & flasher are available from Clssic Parts. I would think Napa could get them also.
1972 Chevy c10 Cheyenne Super
