2 members (baldeagle, Oswald), 42 guests, and 10 robots.
Topics128,012
Posts1,055,316
Members48,419
#436305 07/27/2008 3:01 PM
j54
Offline
The window on the driver's side of my 54 can be slid down pretty easily by grabbing the window and pushing down.Is a worn out spring the problem? Can I get a spring and rebuild kit to fix it, or should I get a new regulator assembly? Thanks.
j54 #438120 08/02/2008 5:07 PM
j54, the best thing to do is to take the cover plate at the bottom of the door off and look up there and then you will have the answer to your question. Use a flashlight not a match! grin
~Jim
Moderated by  ndkid275, Phak1
