| | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | OK, I know that this has been beaten to death in the past, but just so I know that I have it right... The 16"x4.5" wheels with 6 clips were the standard wheel on the AD 1/2 tons, right...? A factory option was 15"x5.5" wheels with 3 clips, right...? Clips for the AD hubcaps can be installed on the later TF truck wheels, right...? My tire shop guy is trying to convince me to get rid of my narrow 16" wheels and go with the wider 15" so I can get cheaper and better tires, and, be safer too. He says he can match the original diameter of the 6.00x16 tires with a 215 85 R15 so speedometer accuracy isn't affected. I'm OK with that, but I just want to get the right wheels at the salvage yard and be able to use my original hub caps. Thanks, Steve p.s., the '54 261 engine arrives tomorrow from the machine shop!!!  | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I really don't know anything about correct wheel sizes but the rolling chassis I bought for my 54 has 16" split rims with 6 bolt pattern. Right now they are playing the roll of making it a "rolling chassis" but when switchover is complete, I will not need them if they will help someone else out with their project. Let me know, G.H. | | | | | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | Well now I'm really confused.....
I just got back from the salvage yard, and I saw trucks with 15 inch wheels that had three clips and some with 6 clips.
It appears that the Task Force Trucks used the 3 clip wheels and the AD trucks used the 6 clip wheels. Is this correct?
Are the 15" TF wheels 5.5" wide like the 15" AD wheels so I could "mix and match" on the same truck?
Can the AD hubcaps be used on the later 3 clip wheels? OR, will only the TF hubcaps work on the 3 clip wheels?
Any input appreciated! Steve | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Actually, the stock rims on the AD trucks were 4 inches wide. Optional was the 4.5 inch wide ones, and the 15 inch rims resulted in the truck meeting the max GVW rating. GM changed from 6 clips to 3 at some point, I am not sure when, as a cost saving measure. The hubcaps stay on the same either way. But I have seen 15 inch rims with 6 clips. | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | 53: I have two NOS 16" wheels that have only 3 clips. Clear as mud, huh?
Winona 1949 3100 5 Window Deluxe Cab
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The number of clips really doesn't matter, as long as there are at least 3. What does matter is the wheel/tire clearance to the tie-rod end on the front end.
To maintain clearance, you need rims with the proper set-back. Measure this by placing a straightedge across the back side of the rim and measure from there to the mounting face, the part of the rim that sits against the brake drum. You need to find some wheels that are close to the originals. You can go with less setback, as long as your rear tires don't rub the fenders.
Most modern gm 6 bolt wheels will accept your hubcaps. If they don't have the clips, you can put your clips on newer rims without a lot of work.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | Thanks for the info guys!
I'm heading to the salvage yard tomorrow. I'm hoping to find a set of wider 15" wheels that aren't all bent outta shape. I'll go with the later GM rims if I have to, but I'd really like to stay with the original GM wheels.
Steve | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | 53, I just came from the garage where I measured my stock '54 wheel, without the tire mounted. It is a 15 inch by 6 inch, inside. The wheel has 6 clips. I believe these wheels to be the originals for my truck. Hope this helps. Lonnie | | | | | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | Im using 15/8 six lug blazer rims on my 51 ,3100.with p-235 tires,Im also using chrome trim rings ,and I installed hub cap clips four per wheel and have the chevy reproduction stock type hub caps,I had to make adapters for the caps to fit the blazer wheels ,they look great on the truck. Wayne,old navy 51........................... | | |
