1 members (baldeagle), 91 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#437701 07/31/2008 10:58 PM
I picked up an engine today that was supposed to be out of a '63 Chevy II. However the casting code is 3788378, which I think is a 292 from a truck. The suffix code is F0I3IH. The I's maybe 1's, My old eyes aren't as good as they once were.
Any thoughts?
57cameoguy #437708 07/31/2008 11:26 PM
the easy way to tell a 292
all 292's have two, 6'' side valve insp covers
dist is located between cyl #'s 1 & 2
below the dist at #1 is a spin on oil filter pass side
they are 1.75'' taller BUT the same length as all other L-6, exclude 302's and 308's
side offset motor mounts.
i don't believe they ever came in II's
http://www.inliners.org/ see casting numbers
http://www.yearone.com/updatedsinglepages/Id_info/gm_engine_id/gmidimages/decode3.jpg
http://www.yearone.com/updatedsinglepages/Id_info/gm_engine_id/gmidimages/decode4.jpg
http://www.yearone.com/updatedsinglepages/Id_info/gm_engine_id/engineinfo6.html wink
3788378 is according to inliners a 292 big_eek sleeping time~r ... a big torque motor for such a small auto.
Jim & Caroline
carolines truck #437719 08/01/2008 12:28 AM
They wouldn't come in Nova's, but what a sleeper. "It's only a six." "No, I don't know how big."
Reminds me of the time we managed to get a 396 into an early Nova. It took some cutting and welding. Ford Top Loader transmission and the shift lever leaned toward the passenger's side for some reason. Cardboard rear quarter windows and snow tires on the front. It paid for itself pretty quickly.
The hardest part was finding front springs. The first set we tried wouldn't give even with 300 pounds jumping up and down on the front bumper. I think we ended up with springs from an air conditioned 327 Chevelle.
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
starkweatherr #437851 08/01/2008 11:33 AM
http://no25.chuckthetruck.com/page3.html
H jives with 63 ChevyII 194
