7 members (Bill Hanlon, tclederman, KEVINSKI, Sjm, Oswald, 2 invisible), 162 guests, and 2 robots.
Topics128,260
Posts1,058,288
Members48,485
#437100 07/30/2008 12:35 AM
X
X Offline
are the 1939 chevy frames and the 46 chevy frames similar? i have a 46 frame and am lookin at a 1939 cab, will the 1939 cab fit on 46 frame??? thumbs_up thanks
'America's about speed. Hot, Nasty, Bad-[censored] Speed.' -Eleanor Roosevelt
Welcome to the 'Bolt!
They aren't the same. One thing that I do know is that the runningboards on a '41-'46 are 1 1/2" longer than a '40. Also, the '41-'46 firewall of the cab protrudes foward 1 1/2" compared to a '40.
The '39 bed is also narrower than the '40 and up bed. I have both beds, if I can remember I will measure the distance between the bolt holes where the bed attaches to the frame. That might tell us if the '39 frame is narrower, as I suspect.
39 bed is 46.5 inches wide... 40-46 bed is 48.5 inches wide. As mentioned the 41-46 cab is longer than the 39-40 cab.
Are you building a 41-46 with the 39 cab? If that is the case the 39 cab will bolt on. The bolt holes in the cab are the same 39 to 46. As Steppenwood said the fire wall is bumped out 1 1/2", the indent in the center of the fire wall for the valve cover is the same 39 to 46. The cab on the 41-46 is mounted 1 1/2 inches back for that bumm out. If you use the 39 cab for a 41-46 with a v8 you will have the extra 1 1/2" in the engine compartment. If you are going with a 39-40 nose you will have to move the cab forward 1 1/2" and change the front spring mounts. Then you have the frame length and bed differances as mentioned.
I have seen people post the term "short Bed" with reguard to 41-46 years. Is there such a thing?
These guys know the dimensions. I just have a guess.
The short bed and long bed may refer to the difference between 1/2 ton and 3/4 ton beds. The 3/4 ton bed is longer with an extra stake hole.
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
