8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln),
78
Mod | | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43725 11/29/2001 7:51 PM | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | I have 2 chevy fan blades available to use on a 235 engine with the short shaft w/pump. One is off of a 216 (18" dia) and the other I got at Hershey for $4 (17" dia) and I don't know what it is off of (not sure anyways - could be a 283). What is the proper diameter of a 235 blade? Any way of positively identifying it? As always Thanks for wisdom. | | |
#43726 11/29/2001 9:00 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | What year 235? The 53-54 engines had the old 216-style fan blade on a 4" pulley and 7/16" belt. The blades will be "staggered" or not evenly spaced around the hub. The 55-62 engines used a fan with evenly spaced and wider blades on the 7" pulley.
They won't interchange because the fan RPM range was different, pulley sizes were different, and the fan bolt pattern (i think) was also different. Whatever blade bolts to the pump pulley and clears everything should work.
Chip
[ 11-29-2001: Message edited by: chiphead ]
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#43727 11/30/2001 3:44 PM | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | Thanks Chip. This is for a 1960 (March 28th) truck 235 engine from Flint. Both blades are symetrical (but not evenly spaced). In fact, the only difference between them is the tip to tip diameter. :confused: | | |
#43728 11/30/2001 7:26 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I'd use the biggest one, if it fits okay. I would also be wary, these old blades can break easily, resulting in severe injury to anyone in its path. I would bead blast it clean and do a careful inspection for cracks before painting. The fans for the 235 are getting a little scarce, and no one makes them anymore. I can remember buying a 5 blade fan for a 230 when we added on a/c, the parts store had them in stock. Shows how much things change in 35 years.
Fred 52 3600 69 C-10
