2 members (Peggy M, Simso),
291
9
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | Finally got my '49 on the road and still can't figure out why the brake light isn't getting power. First off, the running light works fine, and I'm getting power across the fuse for the taillight but am not getting power down to the new stop light switch I installed. From the fuse does the wire run straight down to the switch or somewhere else? It's hard to tell. Anyone have a wiring diagram? Thanks for the help! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Lazy J, The power for the stoplight comes from a connection on the headlight switch (not switched), through the fuse and straight to the stoplight switch. From there it goes back to the light. I have enclosed a picture from a great online source. Thank Mr. Hardy if it helps you. http://chevy.oldcarmanualproject.com/electrical/wiring/pdf/49truck.pdfStuart | | |
