5 members (klhansen, 52Carl, 55shaker, Shardean, Ponchogl), 87 guests, and 3 robots.
Topics128,022
Posts1,055,352
Members48,420
I need to replace the inner and outer cowl panels on both sides of my cab. I will also have to replace the inner to outer cowl panel on the passenger side. Is there a preferred order to doing this ?
I thought I would just do one panel at a time and only replace what has to be replaced, so I do not get anything too far out of whack. I already have the patch panels, and have read about the problems with the inner to outer cowl panel not fitting well, so I am REALLY looking forward to messing with that. Body work is not my strong suit - give me a motor or chassis any day.
I am finally done patching the floor and am ready to move on.
http://community.webshots.com/user/49chevyman?vhost=community
"The only people who do not make mistakes, are people who do not do anything."
If your floor is already in and you're not going to have to replace the sill, just do everything together. The sill and floorboards will keep the cab in alignment. I'm in the process of doing mine and found even a badly rotted cab like mine will hold it's shape unless you really go crazy cutting stuff out of it.
The big issue with the inner-to-outer cowl is the fact that you'll have to verify the fit between the fender and the cowl and adjust the inner-to-outer to hold the outer cowl in a shape that matches the fender. I haven't gotten to that part yet so I can't say which is the correct shape.
Also measure the width of the cab at the point where the width of the hood has to go. You could go wrong here if you don't measure and/or test fit.
I wouldn't consider this job done until you have test fit the fenders and hood together.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
You will find that the inner to outer cowl pieces will take some modifications before fitting. Also, the curve on the bottom of the kick panels will not be correct. If at all possible you should check door fit throughout the process.
1951 1 Ton Completed
Thanks guys. I guess I am lucky or blessed. I did not have to replace any big sections of the floor. The worst part was the part directly above the brace that the front of the cab mounts to the frame through. All flat, so I just cut a piece of 16 gauge and welded it in. There was also some rot around the emergency brake hole.
I am only going to have to replace the lower 12 to 14" of the outer cowl panels, so I am hoping that the hood and fender fits are not messed up.
