| | | Forums66 Topics128,095 Posts1,056,078 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Question? best place to hook the VA tube to carb, I have the old auto choke hole and the bottom rear of the plate (commonly wher pwr brakes runns into). Cavebull | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Carbs original made for the 216/235/261 all had a vacuum port for the advance. That port pulls more vacuum with increased airflow as the throttle is opened further and rpm increase. That's really the only connection where a vacuum advance makes sense and works right.
The manifold vacuum would be a bad place for the advance as vacuum drops with opening of the throttle.
Autochoke carbs require an open tube that goes to a heat stove attached to the exhaust manifold or pipe. Plugging that opening or connecting anything else messes with the carbs basic function. Best to go with an Universal Manual Choke conversion kit. Napa has a simple one.
| | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Ok, so plug maanifold at the base. easy You scare me a bit as I have manual choke on the primary and no choke on the dumper. Both have the ports for the autochoke tube.How bad does plugging it affect the carb function? What should I look for and could I see it anyway?
Does anyone know what/where the vacum attahment was on Roch 2 barrels?
Cavebull | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Depending on the carburetor, there might be a vacuum port about halfway down the main carb body casting. Some 2G Rochesters did not have a ported vacuum fitting. The port you're looking for should have no vacuum at idle, and the vacuum should come on with a small amount of throttle opening as the engine speed is increased. The simplest way to find the right fitting is to use a vacuum gauge and look for a port that gets its vacuum at part throttle. Jerry
