| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 28 New Guy | | New Guy Joined: Feb 2007 Posts: 28 | I have the cab in bare metal, and am almost done prepping the inside of the cab and finishing up all body work. My question is, when I am donewith this, I intend to shoot the entire thing, inside and out with epoxy primer, and then during the recoat window put on the high build urathane primer in preperation to block. Does this sound correct. The man at the autobody store said not to use etch primer with the epoxy as there may be adhesion problems. Does this procedure sound good to everyone or am I missing a step.
Jim Elder Pembroke Pines Florida 64 GMC Stepside Grandaddies Truck Purchased New March 1964 AR Dyer Buick Hardinsburg Kentucky
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I don't know that it is necessary to use etch primer. Some say that it is for new metal. I have used it on a couple of restorations before using the primer. They turned out fine. I think makeing sure the metal is clean before using either is most important. Cleon
| | | | | Joined: Feb 2007 Posts: 28 New Guy | | New Guy Joined: Feb 2007 Posts: 28 | Thanks for the reply, I know back when I was young and spry we simple would just wipe it down with laquer thinner and shoot that old red primer and then paint. What do you suggest using to ensure that the metal is clean? Or just good wiping with lots of laquer thinner and lots of rags
| | | | | Joined: Jan 2007 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 93 | Jim: There is now a product specifically for cleaning before paint. It is called wax and grease remover and is available from auto paint supply stores. I use it rather sparingly by putting it in a squirt bottle, spritzing on the surface, then wiping off with a clean paper towel. It is important to wipe it off before it dries to get the contaminants off. I usually work a 2'X 2' area at time to ensure it doesn't dry before it is wiped.
I hope this is helpful. Regards, Steve New Orleans
| | | | | Joined: Feb 2007 Posts: 28 New Guy | | New Guy Joined: Feb 2007 Posts: 28 | Appreciate the info, I need to go by Terry's Auto this week anyways, I believe I will pick me up some of that
| | | | | Joined: Feb 2007 Posts: 28 New Guy | | New Guy Joined: Feb 2007 Posts: 28 | Well the man at Terry's Auto in Hollywood was great to talk to answered all my questions. AM going to be shooting the entire cab inside and out with PPG DP 40LF. I also picked up the wax and grease remover, and some Rage Extreme. The rage extreme is extremely easy to work. thanks for the advise
