5 members (tclederman, pauld, 2-Ton, Charles in CA, 1 invisible), 139 guests, and 3 robots.
Topics128,266
Posts1,058,367
Members48,485
#43512 04/09/2002 2:18 AM
Junior Member
Junior Member
I want to run the wide belt on my 42 1/2 ton with a 57 6 cyl. engine but the waterpump pully is much smaller in diameter. Will I have a problem with cooling. I have all the stuff to run either belt but I want to try to keep the enging looking as original as possible.
#43513 04/09/2002 4:56 AM
The half inch belt (smaller) will work just fine. The balancer and water pump on the 57 will have the narrower pulleys. If you are using your old generator, you can swap out the pulley on it. Confused about the pulley diameter being smaller. Which pulley? If it's the water pump, you should put on a larger pulley.
Fred
52 3600
69 C-10
#43514 04/09/2002 1:13 PM
:confused: You said you want to run a wide belt........all pulleys will have to compatiable for the size belt. by this I mean witdth.
You then mention a pulley is smaller in diameter. Diameter has nothing to do with width.
So I am confused as to what you are asking?
If you could explain again we may be able to help you out cool
37 Chevy 1/2 Ton
86 Chevy Blazer
98 Drudge 24 valve Cummins
One worn out Timberjack
