3 members (66flea, BC59, dt235sd), 184 guests, and 3 robots.
Topics128,087
Posts1,056,106
Members48,434
#43467 03/29/2002 2:34 AM
Junior Member
Junior Member
Ok scratch the frame swap how hard is it to install a IFS to a '53. Have heard different point of views on this subject and was wondering which was the best to use and what the average $ was.
Thanks again for the last answers they helped sway my desison.
:confused:
#43468 03/29/2002 4:34 AM
HiPo shop has many, many threads debating the different options...in a nutshell, here's the players-Mustang II, Camaro/Firebird/mid-size GM clip, or AMC Pacer. The Pacer allows a stock ride height(not lowered) and replacement parts are HARD to find. The front clip off of Camaro, Monte Carlo, et al offers full replacement parts coverage, but may have too wide of a track for your truck, plus you have to cut off the front 1/3rd of your chassis. This leads us to the Mustang II. VERY popular swap, all kinds of replacement and upgrade parts are available, and kit crossmembers requiring almost no frame cutting are fairly reasonable. If you can weld with a MIG, or have an acquaintance who can, then this is a no brainer. Save up for the Mustang. It will be worth it.
Wannabe smile
P.S. Go to the Gallery and check out ChuckTheTruck's website link. His pictures do a pretty good job of illustrating how relatively easy the Mustang II is to install
"Don't expect anything and you'll never be disappointed"
#43469 04/10/2002 5:03 PM
Anonymous
Unregistered
Anonymous
Unregistered
the only kit i have used was from streetrod engineering and it fit perfect.but i've heard people had good luck with fatman and hiedts. they are all around $350-$425 for a basic crossmember and aroung $1200-$1500 for hub to hub. check out there websites . big brake upgrade on these kits would be a good investment for a truck.
good luck
