| | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43254 12/08/2001 3:09 AM | Joined: Nov 2001 Posts: 31 Member | | Member Joined: Nov 2001 Posts: 31 | Has anyone tried using this king pin kit instead of the standard one availvable from Chevy Duty, etc? I just read the review about it in the recent isue of Classic truck Trends magazine. Thanks! | | |
#43255 12/08/2001 3:20 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | What's the story on the kingpins, I haven't heard about them? :confused: | | |
#43256 12/08/2001 4:58 AM | Joined: Nov 2001 Posts: 31 Member | | Member Joined: Nov 2001 Posts: 31 | This kit uses needle bearings instead of brass bushings, so lubrication, longevity and steering response are supposedly vastly improved over the usual resto. kits. Also, the kingpins and all parts are made of hardened stainless steel or chrome and the kits are designed to fit stock spindles. I have not compared the costs, however. | | |
#43257 12/08/2001 6:24 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I wouldn't use stainless. To much problem with galvanic corrosion with other metals, and the heat treatment is far more critical than alloy steel. Hard chrome would be okay, but will require careful installation to avoid damage. Needle bearings are great, just keep them lubed.
Fred 52 3600 69 C-10
#43258 12/09/2001 3:25 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I know Packard used needle bearing on thier car's kingpins, on the more expensive models. As far as the stainless kingpins, I don't know how they would be.  | | |
#43259 12/09/2001 5:18 AM | | Anonymous Unregistered | | Anonymous Unregistered | I read the article too and I am tempted to give them a try. The Stainless king pins are hardened stainless and the kit comes with zerks for the end caps as well as O-ring seals. If you lube them once in a blue moon you shouldn't have any problems with galvanic action. I am sure they will be plenty expensive . . . but heck, what is money when your old truck is concerned!  | | |
#43260 12/09/2001 6:32 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | That is right, no cheap stuff on our trucks!
#43261 12/09/2001 5:07 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | 25 years ago when I was at the bus garage, we installed stainless bushings in the school bus spring shackles. The kit replaced the soft metal bush with a stainless sleeve which had a spiral wound bushing like a close coil spring inside, plus a hardened shackle or eye pin.The kit reduced bushing replacement in the **** buses from once a year to just about never replacing them again.We also tried a bigger version in the king pins that worked out great.By the way ,on the IHC busses ,the stock bushings lasted 3 times those of the FORDS or GM full size buses.Stock soft metal king pins on older working PU's last about 50k miles if you grease them regularly. Loose king pin bushes cause the axle and spindle eyes to get egg shaped from the pounding of the loose pin.If you check the spindle eye of an old truck, most are worn egg shaped.Might be a problem with a Torrington needle bearing being forced out of shape when pressed in.A brass bush is more tolerant of dirt also.But if the suspension is in good shape, I bet the kit will improve the steering . | | |
#43262 12/09/2001 5:35 PM | Joined: Nov 2001 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 128 | I have not read the article yet, does this kit apply to 45 GMC P/U's as well" WHere can I find out more about replacing the King Pin's? I have never replaced them before and need help on this. | | |
#43263 12/09/2001 6:16 PM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Dumb question, what is Chevy Duty? :confused: :o | | |
#43264 12/10/2001 12:18 AM | Joined: Nov 2001 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 128 | Not sure where that comment came from, nor who it is intended towards. Must be the built up frustration from owning a Chevy?!  | | |
#43265 12/10/2001 12:40 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | It wasn't a remark toward anyone. I have seen Chevy Duty and was wondering if it is a company or just a generic term for Chevy parts?  | | |
#43266 12/10/2001 12:54 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
#43267 12/10/2001 2:28 AM | Joined: Aug 2001 Posts: 3,619 Moderator | | Moderator Joined: Aug 2001 Posts: 3,619 | Chevyduty is where I've been getting some of my parts.Real friendly a knowledgable people and orders shipped at once. Just wish they wern't instate so I wouldn't have have to pay sales tax.
DON 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | |
#43268 12/10/2001 4:53 PM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | As Tony mentioned if have found the majority of 50 year old half ton spindles Ive seen have egg shaped holes. I mention half ton because I think by design, the "floating bushings" in half tons cause this condition to be more likely. This could be a problem for needle bearings. I like to replace the "floating bushings" with slightly oversize ones that will press in and then ream/hone to size.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
#43269 12/11/2001 12:26 AM | Joined: Nov 2001 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 128 | To: Whitelightning
I did not read your post that way originally, now that you explained it, I can see where you were coming from and I appologize for my comment. | | |
#43270 12/11/2001 3:13 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Thank Formula1, When I look at it myself, it probably was the wrong way to word the question. I'll have to check out Chevy Duty Website. I usually get parts from Jim Carter or at the Canfield Swap meet in Ohio.  | | |
#43271 12/11/2001 4:46 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Checked out Chevy Duty, great website. I think I'll have to get a catalog when I start putting this truck back together.  | | |
