8 members (Otto Skorzeny, Shaffer's1950, SlimSix, Hotrod Lincoln, TrknGMC, homer52, 2 invisible),
79
Mod | | | Forums66 Topics128,139 Posts1,056,451 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 114 Shop Shark | | Shop Shark Joined: May 2008 Posts: 114 | I've often heard about the 'splash system', 'oil dippers', etc. when talking about the old 216's. I've never looked inside of one of these motors before, surely there is an oil pump of some type, if not how does it generate the little oil pressure that it has? I have one old truck with this motor but have never had to take it apart. Thanks, James | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Oh yes indeed there is an oil pump. The splash and drip refers to the rod and main bearings but the rocker arm assembly gets oil from the pump. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The main bearings and the cam bearings get pressure lubrication via the oil pump. The rockers are also supplied by a pressure feed. The rod bearings work on a dipper system in which the dipper supply comes from the oil pump. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | truckernix is correct about the "full-pressure" lubrication of cam and main bearings, the rocker arm assembly, and the timing gears). The "dipper" system for rod bearing lubrication is not really a "splash-oil" system (as many people now call it) - see below. Quiz: Does the "dipper" system actually collect oil as the dippers move through the oil near the bottom of the pan? Or, do the dippers receive oil that is sprayed into them by an array of tubes that are fed by the oil pump? Or, does the "dipper" system rely on a combination of the above? The answer is : All of The Above (see the lubrication section in this Shop Manual). | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Our description in the 50's was Chev had a solid crank and GMC had a hollow crank. That's why GMC's were more prone to rear main seal leaking. There was more oil there. | | |
