2 members (78buckshot, NJC), 99 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
#43190 01/17/2004 6:39 PM
Does anyone make a spacer for the rims for 3/4 ton chevy 1951 with 8 lug rims ?
Changed from stock 17" to spoke wheel 15" rims but the 15" steback is to deep and rim hits tie rod end when wheels are stright. any ideas? allready Tried driveing around in cricles didn't like it. thanks Bill
Bill 1951 3/4 ton 5 window pick up
1955 GMC 1/2 ton longbed automatic
Junior Member
Junior Member
I found a set of spacers for my 51 3/4 ton on eBay, they are 1/4" and gave me just enough room to put rims from a 96 3/4 ton Chevy. I had a clearance issue in the front. I still need to install the original hub caps. Did you ever need brake shoes for your truck? I'm having a hard time finding them at reasonable price.Checkhere.
.http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33749&item=2455991304
1951 Chevy 3600, 1996 Yukon, 2000 Road King
It is easy to take liberty for granted, when you have never had it taken from you.
http://www.stovebolt.com/gallery.htm
Ihave a new set hanging on my wall.
I thought I have to use them with the newer rims.
Lucky I found some brand new rims with a better off set and I have enough space.
can't get into the garage yet, wify still sleeping ( it's 8am)what a woman
If you would like them contact me via regular e-mail
[email protected]
Fritz
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
You make your wife sleep in the garage?
:p
54 3100 with 235
62 flatbed dump C60 with 261
Rickcapt I know shoes can be found for around $80 and another $75 or $80 core charge for the rears. Most places will not reline them because of the asspestos in them. I found a good used pair in a parts yard after a few trys for $20.
