3 members (tesa, 55shaker, Bill Hanlon), 58 guests, and 0 robots.
Topics128,076
Posts1,055,924
Members48,430
#431164 07/09/2008 11:06 PM
The valve gear, and probably most of the rest of the 235 hi pressure is filthy. Little beehives of dirt on the rocker shaft supports, etc.
I'd like to get as much dirt out of the engine without rebuilding as possible, although I will rebuild when funds allow.
Right now there is no oil filter on the engine, and it has the vented valve cover.
Any suggestions about getting the crud out without a teardown? I will at least add a bypass filter, and may build an oil dialysis system for it.
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
These engines are pretty easy to take apart, clean and inspect and even easier to put together again with fresh gaskets and new parts if anything is worn beyond spec.
If you want to keep driving before a complete rebuilt, take off the head and clean everything and go with a fresh head gasket.
The valves will tell you a lot about the history and use.
Do a compression test before and after.
Motor flush is too harsh for a clean engine and can clog the oil pump screen of a dirty engine, if bigger chunks don't get fully dissolved and break free.
I have read too often about folks seizing an old engine going the easy route with just a quick motor flush.
Lots of elbow grease, scrapers, metal bristle brushes, detergents and solvents always do the best cleaning job...
It's a bonding experience with your old iron and you will not regret it.
My old 235 was never really dirty inside when I got her 13 years ago. And after over 30 years on the road since last rebuilt, she is still as clean as new.
I rebuilt the head a few years ago and compression and power is still in the 90%.
Typing this still blows my mind and gives me goose bumps.
Stovebolts are as bulletproof as they come.
Keep 'em clean and running ...!
On the road every day...
1952 Truck - 235
1948 Coupe - 261
You're right, of course. I was hoping for a cheap and greasy solution, but it sounds like I'll have to pull the head.
I just want to get my Langdon Holley-Weber kit installed and run it for a few minutes first. Just a few.
i agree........just taking the head off will show you how much build up you have in the journals.......spend 100 bucks for gaskets and misc. things and some elbow grease and make a day out of it.........
