6 members (GusG, Youngin' Tut 59, FAST55, Buckeye998, J Lucas, 1 invisible), 97 guests, and 0 robots.
Topics128,196
Posts1,057,386
Members48,469
OK, I can't seem to find an answer to this anywhere. Perhaps you might know. I'm working on restoring my 1949 Chevy 216 engine and do not remember if there was a gasket between the mating surfaces of the front bearing cap and timing cover plate. These surfaces are secured by two bolts inside of the oil pan. Seems like there should be a gasket but one was not included in the engine overhaul gasket set I purchased from NAPA.
49 Truck Nut
There is a gasket between the block face and the plate. The 2 small bolts ,if I understand you correctly, are the lower securing bolts for the the timing gear cover.It is conventient to redrill and tap them from the front so if the timing cover needs to be removed in the future,the oil pan doesn't have to be removed first.There is also a viton semi circle gasket between the oil pan end and the bearing cap.
Drew
The front bearing cap does not seal against anything. In front, the timing cover seals against the front plate through a gasket. The pan seals against the rear of the plate through the semi circle pan gasket.
1951 1 Ton Completed
This is excellent advice and unless you are going for a historic restoration this is a great little mod.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Drew says there is a gasket and Truckernix says there is not. I guess if the oil pan end seal and timing cover gaskets are working, why would a gasket be needed between the front main bearing cap and block surfaces? After looking closer, I did notice remnants of a gasket between those two surfaces. Any other thoughts? Thanks for the timing cover bolt modification idea - I will try it!
49 Truck Nut
I did not say a gasket is between the "front bearing cap" and the "timing cover plate" using your descriptions. I said a gasket between the block face,meaning the end of the engine block, and the mounting plate that attached to the block before the crank gear and camshaft and gear are installed.Truckernix is correct.
Drew
49Trucknut,
when you remove the bearing cap, there are usually very thin metal shims between the cap and the block. Is this what you are talking about?
This is a classic example of the importance of including a photo with a question.
Woody
Door Art Collection
OK, I agree, a picture is what we need. I am not talking about the shims. I tend to agree with Truckernix but can't figure out what the gasket I'm looking at is doing. I have a great picture that I'll email if you are interested, just send me a PM. By the way, the gasket kit I have includes this gasket but because of how the cap attaches to the block and to the timing cover plate with 7/16 bolts I just can't see how this is a very effective or necessary seal.
49 Truck Nut
