4 members (Otto Skorzeny, Joe H, HandyAndy, Phak1), 140 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
#431315 07/10/2008 4:05 AM
Where can I find a newer style Master Cylinder, but I DONT want Power brakes. I want the manual brakes still.
I seem to have misplaced a catalog I thought had one, and now im burnt out from welding all day and I thought i'd ask for a hand from you guys.
PoPo- Jarrad
49 1/2 ton project
PoPo #431319 07/10/2008 4:27 AM
american classic truck parts and jim carters both have them. original and dual M/C's. maybe even local auto parts store can get you one?
do they bolt in like the orig or do i need a bracket?
Ok looked in Jim Carters catalog. Thats a stock replacement. Will it work well or should I be looking for a newer style?
I want to be able to stop since I will be having my child with me sometimes and would rather spend the $ now than explain to the wife why ..... well you know
49 1/2 ton project
PoPo #431329 07/10/2008 5:13 AM
ok found one on Amercian Classic and ordered it. the Dual MC setup conversion kit. thanks
49 1/2 ton project
PoPo #431375 07/10/2008 12:08 PM
popo,
here is a master cylinder and mounting bracket from cpp.
you can also search their entire site for a bunch of different options on brake installs.
http://www.classicperform.com/Store/1947_59_Trucks/4756MMK2.htm
but dont buy from performanceonline.com.
that is who i bought from, and their customer servive stinks.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
got the kit from American Classic. Well I went to install the brake lines and bench bleed. I came to notice the front fitting (note it did not come with any fittings) the fitting female hole was FREAKIN huge. I went to FLAPS and they did not have any fittings that changed from such a large fitting back to 1/4" line fitting.
Any suggestions and I am not using the proportioning valve that is an option with this kit.
49 1/2 ton project
PoPo #434460 07/21/2008 1:46 AM
popo, here is the company i ordered some fittings for on my 57.
FLAPS dont have much of a supply.
this place has the all.
http://store.fedhillusa.com/americannuts1-4.aspx
hope this helps.
leonard
