| | | Forums66 Topics128,049 Posts1,055,552 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | Where can I find a newer style Master Cylinder, but I DONT want Power brakes. I want the manual brakes still.
I seem to have misplaced a catalog I thought had one, and now im burnt out from welding all day and I thought i'd ask for a hand from you guys.
PoPo- Jarrad
49 1/2 ton project
| | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | american classic truck parts and jim carters both have them. original and dual M/C's. maybe even local auto parts store can get you one? | | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | do they bolt in like the orig or do i need a bracket? Ok looked in Jim Carters catalog. Thats a stock replacement. Will it work well or should I be looking for a newer style?
I want to be able to stop since I will be having my child with me sometimes and would rather spend the $ now than explain to the wife why ..... well you know
49 1/2 ton project
| | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | ok found one on Amercian Classic and ordered it. the Dual MC setup conversion kit. thanks
49 1/2 ton project
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | popo, here is a master cylinder and mounting bracket from cpp. you can also search their entire site for a bunch of different options on brake installs. http://www.classicperform.com/Store/1947_59_Trucks/4756MMK2.htmbut dont buy from performanceonline.com. that is who i bought from, and their customer servive stinks. leonard | | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | got the kit from American Classic. Well I went to install the brake lines and bench bleed. I came to notice the front fitting (note it did not come with any fittings) the fitting female hole was FREAKIN huge. I went to FLAPS and they did not have any fittings that changed from such a large fitting back to 1/4" line fitting. Any suggestions and I am not using the proportioning valve that is an option with this kit.
49 1/2 ton project
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | popo, here is the company i ordered some fittings for on my 57. FLAPS dont have much of a supply. this place has the all. http://store.fedhillusa.com/americannuts1-4.aspxhope this helps. leonard | | |
