7 members (Gdads51, Phak1, Joe H, Youngin' Tut 59, Greg_H, carbking, Wayne67vert), 99 guests, and 1 robot.
Topics128,137
Posts1,056,430
Members48,441
jdl
Offline
Ok, I figured out the other day that my generator IS working, but it only puts out enough when the regulator lets it, to move the amp needle a bit. Let's say that the needle, with the lights on, is on the far left leg of the "m" in amps, closer to "D." When I rev up the engine, it moves to about the middle leg of the "m." With only the light switch pulled out to the first notch, it barely moves the needle from the center mark(where the needle is when the key is off) but when I rev up the engine it moves it a little past the mark towards "C." Is that as far as it should go, or should it be going farther towards "C"?
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
you really have to have modern test equipment hooked up to know what's going on in these reg/gen systems, they will all act slightly different, especially with respect to what the gauge shows and what the regulator does
the regulators have adjustments to set the 'cut in' and 'cut out' points, and the regulator controls how much of the generator output goes where, depending on the condition of the battery and the demands of the system at that moment
one of the differences between generator and alternator systems is generator output depends on speed - alternators can have higher [or max] output at low speed ... read all about it
Riding in the Passing Lane
Sounds like you are working correctly. When the bat. is full charged there is little or no flow to it. Turn the lights on with out the engine running for a minute or 2. Then start the engine & rev it a little. It should go over into the C area for a while & then taper back to the middle. Turn on the lights & heater & accel the engine The gauge should go up to the middle at least. You can tell more with a volt meter across the bat. It should charge about 7 volts on a 6 volt system & 14 on a 12 volt system. Like Red says a gen. system doesn't charge at idle.
1972 Chevy c10 Cheyenne Super
jdl,
It sounds like you might have a broken connection under the dashboard. Take a flashlight and inspect the floor directly underneath the light switch. If you find a little pile of amps, they might have fallen out of a wire. If you repair the wire, the amps will stay inside and flow through the wire to the battery.
Stuart
jdl
Offline
OK Stuart, I will check. wink Thanks guys, I thought that was correct but I didn't know what to check to make sure.
Jordan D. Long
Photobucket
jdl
Offline
Oh, Bill, I have a multimeter, I'll see what it reads.
Jordan D. Long
Photobucket
