4 members (Bill Hanlon, Gray_Ghost, Otto Skorzeny, Robert Crandall), 160 guests, and 2 robots.
Topics128,162
Posts1,056,945
Members48,458
I need to set the headlights on a 57 chevy truck. Is there an easy way to do this with out a headlight aimer that is in the manual? I was guessing we could use markings on the wall or something.
yeah, a garage door or blank building wall works fine
jdl Offline
When you buy replacement headlights on the box it says that if it is not convenient to take it to someone who can aim them professionally, to do what red58 says above.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Aim the driver's side just a bit lower than the other for the benefit of oncoming drivers. If you have them set too high, they'll let you know.
Doug
How high should the beams be? Same height of the truck or a little lower?
try 2" drop at 25' .... I think it's actually specified by the jurisdiction you're in, might ask at a shop
The left one should also be aimed slightly to the right and lower as Doug suggested--
Glenn
Thanks guys! Found out wire switched on one also, so I had one bright one dim at all times. You wonder how some of these things happen.
