| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | The stainless windshield trim clips for the deluxe trim on my '58 burb are original, and measure 1 1/2". I thought I would order new clips from Jim Carter when installing the new windshield. When they arrived, the clips measure 13/16". I called Jim Carter to find out why the clips were more than 1/2" short, since the gap might expand or shrink with new weatherstrip.
Jim Carter personally called me back to discuss the issue and went and measured his own original clips which were the same length as mine. He gave me the name of his supplier, Mar-K, and I called them to find out if I could obtain the proper length clip.
Mar-K sells the clips for $1.00 each, and four are required. Mar-K quoted me a price of $5.00 per clip plus a shipping and handling charge of $8.95, for a total of $28.95 for four, 1 1/2" clips. What a rip-off!! Maybe they will sell me a hacksaw blade for $25.00 so I can cut my own.
Has anyone used the smaller replacement clips, and do they cover the gap adequately? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You need to call Jim Carter back and tell him that story. He is an extremely honesy Guy and will get after his supplier. I have always found them very helpful. If you can not get satisfaction, I would not use the short ones I would wait for some on Ebay.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | Thanks for the reply, and Happy Holiday. Jim Carter is a true gentleman, and took this problem seriously, calling several times. I told the people at Mar-K I would not be extorted, but they didn't seem to care. Ah, the trials and tribulations of restoration!! | | |
