1 members (RoseB), 109 guests, and 3 robots.
Topics128,195
Posts1,057,374
Members48,469
#42779 03/31/2005 4:08 PM
Last year when I first got my rebuilt 261 going with a rebuilt Rochester Monojet carb, things were great. But as time went on, it has become more difficult for me to adjust the carb. And yesterday it started whistling.
Is the whistling a symptom of something specifically wrong or is it something I just have to live with?
(I'm going to look at a Carter YF that Stevejumpr gave me a lead on so I hope I won't have to put up with the whistle for long.)
#42780 03/31/2005 4:13 PM
That whistle is probably caused by a vacuum leak. Check the base mounting nuts for tightness, but don't break an ear off the carb by getting too energetic with the tightening. A propane torch with the gas turned on, but not lit, will help find the leak. With the engine idling,move the torch tip around close to the base flange, and any vacuum lines in the area. When the gas is picked up by the vacuum, engine speed will increase, and it might smooth out, also.
#42781 03/31/2005 4:56 PM
If you don't have a torch, starting fluid works the same way. Check the carb horn to body seal too.
Enjoy the time finding the problem and fixing it....isn't that what these old trucks are all about?
#42782 03/31/2005 6:17 PM
What Makes Carb Whistle?
It doesn't know the words?
#42783 03/31/2005 9:59 PM
Some carbs just whistle without there being a problem with them. It is a function of how the air flows through the venturi and throttle plate. You may be able to get it to stop by changing the air cleaner or putting a baffle in it to swirl the air to make it stop.
Paint & Body Shop moderator
#42784 03/31/2005 11:29 PM
Riding in the Passing Lane
Mono-jets are bad about leaking between the throttle body & fuel bowl. sometimes tightening the srews will fix it. Put lock washers under the heads if it doesn,t have them. You can put a new gasket in without tearing it down if you are carefull. There are 2 different gaskets for them. Make shure you use the right one & get it in correctly. Dont give up on it. They are a good carb if you get it right.
1972 Chevy c10 Cheyenne Super
#42785 04/04/2005 12:11 AM
Thanks guys. Maybe I solved the source of the whistle.
The Monojet was great 13 months ago but seemed to go to pot in the last couple. I think it was an intake manifold leak.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=008962
#42786 04/11/2005 3:03 PM
I replaced the manifold gaskets and everything is wonderfully normal. No whistling and the Monojet is smooooth.
CanyonAG77, the 261 just hums.
Thanks!
