2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#427182 06/27/2008 3:09 PM
I put a new ignition switch in my 48 1/2 ton Chevy truck and rewired the whole truck. When the key is turned to the right, the key wont come out and there is no juice. When turned straight up and down, the key comes out and there is juice. When turned to the left, same thing....I dont think this is right. Any help out there? Are my wires on the back wrong?
Riding in the Passing Lane
You have it wired wrong. Everything is off straight up & down. When turned to the right everything should be on. When turned to the left just the accessories should be on. It might be marked on the back by the terms. B is battery I ignition & A accessory.
1972 Chevy c10 Cheyenne Super
Sounds like you switched to a more modern switch. Stock is off/on to the right.Check your wiring.
Drew
Ex Hall Monitor
Ex Hall Monitor
I agree with DrewP. My old 55.1 had a two position switch off/on, no accessory.
jdl Offline
Yeah, I agree with Drew and Tiny, and even the manual only shows off/on, no accessory.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
It is probably a 3 position switch with 2 offs. To the left should be all off and ignition locked. In the middle is all off but can be switched to on without key. To the right is on.
Yes you have it wired wrong.
jdl Offline
I don't understand why someone would make a switch with two offs?
Jordan D. Long
Photobucket
Locked off. Off, but not locked. On.
The acessory position was added so you can turn on the radio, read the gauges or any other without burning the points.
