3 members (lumbersawyer, tclederman, 1 invisible), 70 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#426057 06/23/2008 11:57 PM
Hi Im new to the board but ive been browsing the last couple of months, really like the site. Well I have a 51 chevy 3100, and i am about to buy a complete 74 camaro subframe to graft for cheap, but before i buy it i was just wondering if its to wide, i read on another board that 2nd gen camaros fit fine, i dont wanna do a mustang II, wanna keep it chevy, and i dont want the tires looking wierd in the wells from being wide. I eventually just wanna bag it on all 4's so i want IFS, i know these questions get brought up alot, but what is the best chevy graft i could do, or would the 74 camaro be fine?
I can't tell you nothing the mountains can.
David661 #426170 06/24/2008 4:36 AM
Too wide. can be a problem with wheel selection. I have installed several late 70s and early 80s Monte Carlos. They are narrower than a Camaro and fit the ADs very nice. Novas thru the 70s are a good choice.
1948 Chevy
5 window
"6" powered
#426241 06/24/2008 2:03 PM
Just a question: David said he wanted to bag the front suspension.
Is that possible with the Camaro when grafted into the AD?
~Jim
Do you know the stock hub to hub width by chance of a 3100, and whats the best setup for suspension for airbags, i know mustang 2 is good but its ford, just looking at options before i commit to a certain setup.
David661 #427944 06/30/2008 2:13 AM
I
I Offline
wheel selection can be tough if you want it on the ground. But it will fit we have done 5 like this. You need to find a wheel that is a 6" or yuo can use a 7" if you can get a deep offset in the design you like.
The other option is to move the lower ball joint in 3/4" not that hard if you can weld. Take the lower control arm weld the ball joint closed and redrill 3/4 in.
The top is easy to do with spacers.
iceburgh #428889 07/02/2008 8:53 PM
The Camaro subframe works fine, but you will need to take a 2" or 3" section out of the middle and cut the tie rod down a like amount. This works great, another way is to buy Scott (Ventura, Ca.) A arms that are shorter by about 1 to 1 1/2 inches, but they are pretty pricey. When you narrow the subframe it will align better with the early frame. Air bags will work fine with the Camaro subframe.
Alright Thanks guys, anyone got pictures of their subframe done
David661 #430495 07/08/2008 2:19 AM
I
I Offline
David661 #430523 07/08/2008 3:18 AM
I believe Fatman in N.Carolina has shorter A-Frames also
