0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42591 03/08/2004 5:01 AM | Joined: Nov 2000 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2000 Posts: 21 | I am replacing the touque tube rear end in my 48 Chevrolet half ton with a 9 inch. Can I get a decent ride from the stock rear leaf springs. If I use them I will seperate them, wire brush, paint and use the teflon liners. This pickup will be a street rod hauling nothing more than lawn chairs and easy up awning.
I have a set of Camaro Z28 5 leaf springs with shackles and front mount. Would be a lot more trouble to use, but I want to do the job ONE TIME ONLY.
Any suggestions which way to go
1948 Chevy 5 window "6" powered
#42592 03/09/2004 1:08 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Teflon liners in leaf springs are fine , but you will need to upgrade the shocks to help tie it all together and hold down the axle bounce , now that the springs move so much more freely. | | |
