0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 9 Apprentice | | Apprentice Joined: Feb 2008 Posts: 9 | I've put a new (original style) master cylinder in my '41 1/2-ton canopy, but I was missing the original clevis/plunger. Made a new one from a (gasp!) Ford part. I note in my parts catalog that the right part seems to have a locking ring to hold the plunger in place (and also, apparently, to limit return travel on the pedal). Am I reading this right, and does this explain why I'm having such a hard time bleeding the brakes? And, if so, any suggestions on where to find a plunger and related locking parts? Thanks. Will Corbin ( [email protected]) | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Will,
My unprofessional take on this! If the piston is the proper one for the master cylinder, and your Ford piece has the same physical dimensions as the original Chevrolet rod, it should work perfectly.
I think for the master cylinder to function properly, the piston need to retract fully. If your makeshift part allows this to happen, your bleeding problems are elsewhere.
Mixing and matching brake parts would be the ultimate NO-NO, but it sounds like your Ford items are only linkage related.
Bleeding can be tough sometimes, so it is probably a procedural problem as opposed to a mechanical problem...we hope.
I'll bet someone will pop in soon with more specific info and maybe even a lead on a replacement Chevrolet part.
Stuart
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe you should have the correct rod. It has a mushroom on it that goes behind a thick washer that is retained by a snap ring. This acts as a stop for the pedal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2007 Posts: 46 New Guy | | New Guy Joined: May 2007 Posts: 46 | Did u bench bleed the master before installing it? This step can be forgotten sometimes.
It's easier to get older than it is to get wiser.
